Old 12-31-2013, 11:47 PM
Rossba Rossba is offline
Cobra Make, Engine: DRB, 302 EFI 5 speed 9"
Towmaster,
I was tinkering with the rear end today and noticed the tag on the spring was KHRR-12.
So i have the raised ones, probably the same as the one's you took out.
Dont know how low you got yours without rubbing as mine rubs on the inner guard and outer.
I jammed a piece of 20mm box tube under the spring to get some measurements and the ride height still looks good so I am going to try and make the chopping board spacers as you suggested and do some test driving.
Once I get the spring rate right in the front it may be lower.
Do you know your front spring rates?
Ross
