Not sure.
My FG has a stub axle and hub all in one that bolts to the upright with 3 bolts.
The BA hub bolts onto a spindle.
The BA ones are known to fail so if you hunt around some mechanics or suspension shops you may be able to get used one to try.
If the bearings can be removed you may be able to find a bearing that has the correct OD for the Ford hub and correct ID for the VT spindle/stub axle.
Good luck
