I found when i shut the engine off hot the heat from the manifold boils the gas out of the carburator into intake manfold. this stinks up the garage, the house the neighborhood and makes is hard to start when hot since the cylinders are flooded with gas and or vapor lock. Solution is simple. 1/2 phenolic spacer from jegs for 19.99. it is spacer between carb and manifold and insulates the carb from heat. comes with gaskets and studs. Incredible difference!!! no odor
and easy to start when hot
make sure you have an elongated air cleaners as the spacer will make the air cleaner sit up into the scoop, where it should be
a large round air cleaner will hit the hood outside the scoop.
please note you want phelolic or wood as aluminium is to conductive.
