Old 01-02-2014, 10:40 AM
cscobra cscobra is offline
Cobra Make, Engine: ERA #766, FE V8, Toploader
The wheelbox I put on the driver side (fortunately--much easier to remove than the right side, especially without removing the dash) worked in mockup prior to installing it, but it did not work well at all when installed ("floppy wiper" resulted). Upon removal and disassembly, it was apparent that the "drive wheel" was not attached at all (unless you count friction!) to the shaft that drives the wiper arm. I took it to a welder to correct the problem; it now works great.
