  #313 (permalink)
Old 01-04-2014, 07:48 PM
ERA Chas ERA Chas is offline
Originally Posted by lippy View Post
Chas, how low did you set that ride height, and how long did you wait to do it? Looks great.
I think my numbers are a page or 2 back in this thread. This was done in '92 after the second make over. Original front Konis and (then) new Aldan rears. When originally completed in '85, a short series of drives to settle them. Hard braking and acceleration to shift weight is beneficial as are uneven surfaces.
Don't go by a number so much, my numbers may be different than yours, Dan's or the milkman's. Just gradually sneak-up on the look and function. If / when you get rubbing, go back up a tad.
Hitting the brakes hard at a hundred can cause rubbing if you overdo it. Full lock turning seldom happens and always at walking pace.
I wanted the car as low as possible to get the CG down-beneficial dynamically for cornering and braking. Don't just do it for 'the look'.
And never get the nose higher than the rear-level at the worst or a tiny rake. The larger rear tires alone will rake it.
Edit: I may have put my specs in the 'Ride Height' thread...
Chas.
