Originally Posted by DanEC
Not sure I will want to go any lower - my mufflers hang down about 1/2 inch below the frame rails which comes out of my clearance also. I have them sucked up about as high as ERA's header collectors will let me without putting a bend in them. But, I'm not sure I want them much closer to the floor pan.
I forgot about your undercar system so you're right to leave it where you have it now.
I probably used my car more aggressively than you intend. But the negative setting had no ill effects on street driving and definitely improved track and autocross cornering.
But at the very least, strive for zero or maybe 1/4 degree neg.
