Since C is a fixed point and the distance from AC and BC is constant. Then AB is also wants to remain constant along an arc with C being the center point. To keep AB constant you need to move it the same distance along the line of the formed arc. In the end, it doesn't matter, you can always draw a straight line if you're sober enough.
_____________________
