  #355 (permalink)
Old 01-12-2014, 06:20 PM
DanEC's Avatar
DanEC DanEC is offline
Then pull the plug on the voltage regulator, and on the alternator side of the connection, jump a wire across the field and power fields. This will be the first wire U/G and third wire Y/R. Then start the car and rev it to no more than 1500 RPM or so while you stare at the ammeter. Tell us if you have a charge condition on the ammeter.
Here is what I got when I did this last Feb:
"From orange wire terminal on back of alternator to ground for voltage regulator - 12.5 volts (battery geting a little low). No change when I reved it up. The regulator was plugged in.
Unplugging the regulator and jumping the two terminals the voltage from alternator to regulator ground was 14.5 volts and as I reved it, it was climbing to 17 to 18 volts."
Next warm day I guess I will start testing all over again. I may put the solid state VR back in.
