Originally Posted by blykins
Way, way, way too much clearance for a 302 sized main. I set bearing clearance at .0015 on aluminum 302 blocks. With .0035 clearance you will have a considerable oil bleed there, which can cause cavitation and other issues. I don't even run .0035 on windsors and 460's.
If you have the engine apart, I would put some .001 bearings in it at least.
Rods are right on the money...
Engine hasn't been on road yet.
we ran it on the dyno with Delo 400 15w40 60Ib
oil pressure, I could've screwed the relief valve up we were happy with that pressure, the engine has spray oilers. That was on a std pressure Peterson dry sump pump, since then I have purchased a HV Peterson Pro Rotor with single scavenge return in order to reduce plumbing and I may be able to slow the new pump down for less shafted horsepower loss.
My US engine builder has built a lot of race engines and has a good name, so I will contact him and ask him about the clearances. Its not hard to remove sump and change shells.
