Wakeen 19
Did you mount the motor mounting brackets supplied by A&C to the frame?
If so, how did you know where to put them?
I used the motor, motor mounts and the frame motor mounts to position the motor on the frame.
I needed spacers between the frame mounts and the frame.
Also, I think my motor is 1/2" offset to the passenger side.
If I remember one spacer was thicker than the other.
Jim
