I used the supplied frame mounts and the engine mounts from mustangs unlimited. I measured 22 1/2" from the top crossmember back to in between the top middle two header pipes on the block.
If I split the difference between the frame rails, I am still about 3/4" away from the frame to the A and C mounting bracket.
