Old 01-16-2014, 06:32 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Don't give up Wakeen we will get you there. Are you running a 351 engine? does your frame rails measure 24" apart measured from the inside rail?
By the Jac Mac is correct about using a flat pad for your motor mounts to sit on. You may be able make one from a piece of 1/4" x 2" angle iron and just bolt it into place if you don't have access to a welder (assuming you are not compromising the frame rails with additional holes).
"Let's roll"
"Be part of Something Good
