  #137 (permalink)
Old 01-19-2014, 03:53 PM
Dimis's Avatar
Dimis Dimis is offline
Originally Posted by lippy View Post
Brent and I just went through this for my engine. The lifters we chose, and that he is referring to, are Isky bushed solid rollers. No needle bearings. The folks at Isky claim you can even go 50k mi (I'm dubious). This build can rev to 7k+ but doesn't use a completely radical cam or spring seat pressures. Brent can give you more details on the specs, but the performance is impressive - especially for the large amount of rotating mass in an FE. I will need to check the lash once in awhile, but no big deal.
I suspect IF I go the way of solid rollers Brent will packaging a similar set up.
Its a case of Hydraulics will work and work well, but solid will fulfill the intakes potential... either way is a win/win just not sure if I want to leave anything on the table.
