  #368 (permalink)
Old 01-20-2014, 07:36 PM
kevins2's Avatar
kevins2 kevins2 is offline
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
I like the idea of the eyebolts/clips too but I suspect I will stay with the bolt/bracket smount set up. When you're referring to the shoulder harness buckles, do you mean the mounting brackets or the attachment rings to the lap belt buckle?
Thanks Kevin
Sorry I wasn't clear. I'm talking about the shoulder harness brackets that are bolted to the top of your bulkhead. Your current shoulder harnesses are sewn on and won't come off those brackets. I cut mine off because I liked these brackets better than the new ones that came with the 3" shoulder harnesses (they were the same concept, but were flat and didn't have as nice of a finish. The slots are the same width, so you can use either). The replacement 3" shoulder harnesses thread through this bracket and then into an adjustable buckle instead of being sewn on permanently. Since the shoulder harnesses are adjustable at the bottom for different passengers and seat positions, you can adjust the top buckles one time to give you the appropriate length. The ends of the straps will then be tucked into the pads. Sounds confusing but will be obvious to you when you get the new harnesses. You can see all these buckles and brackets in the photo below.
Kevin
"Anyone who drives faster than you is a maniac and anyone who drives slower than you is an idiot" - George Carlin
