Old 01-22-2014, 09:23 AM
Wbulk's Avatar
Wbulk Wbulk is offline
Cobra Make, Engine: 66 Cobra
It's 4 3/4" - 4 7/8" long, front to rear, and 1 1/4" down on the inside. It's a section of a piece of pipe.
Added: That's down from the X bracing that is made of 2X3, that is flush with the bottom of the 2x4 frame. Making the X member 1" lower than the top of the 4" frame. In case you need the length of X members where it attaches to the frame, it is 19" long point to long point.
So with the 1 1/4" plus the 2x3 being 1" down it gives you 2 1/4" from the top of the 2x4 frame for the .
Wayne
"Everything is alive. If you get angry at a vehicle or the trans, it won't fix until you apologize and say you are sorry." "The vehicle always knows what it is doing and what the cause of it's bad feeling is. If you ask it humbly what the problem is, it will tell you. Then you and it will both be happy."
Gil Younger
