Old 01-26-2014, 12:08 PM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by strictlypersonl View Post
Loss due to the offset of the pedal to the pivot bearing support in the frame is negligible. It's all pivoted in needle bearings - very little friction. All the components are stiff enough that there is very little lost motion (and that wouldn't translate into a loss of efficiency anyway).
You can change master cylinder diameter, but there is no such thing as a free lunch. Easier pedal > longer throw for disengagement. You always have to translate the pressure plate force/distance into what happens at the pedal.
Bob - OK, I will forget about the pedal layout. The spacing is nearly the exact same as my Mustang
Can you tell me what size slave cylinder ERA is providing. I don't remember seeing any identification on it. I'm guessing it's a 3/4 or 7/8 inch unit but would like to know for sure.
