Thread: Coupe Alignment
Old 01-29-2014, 10:18 AM
redmt redmt is offline
Default Coupe Alignment
Does anybody have some solid numbers for caster settings? I'm getting numbers from 3 to 9 degrees from different sources. The FF5 coupe is set around 4 right now and it's twitchy as hell on the rough roads. I want to put the final alignment on it but need some reliable numbers to go with.I think I'm pretty good with .5 on camber and 1/8 toe in.
The rear is .5 camber and 1/8 toe
