Thread: Coupe Alignment
Old 01-29-2014, 02:35 PM
Bobcat Bobcat is offline
Couple of things ... are you running radials or bias ply tires ? Also , what tire pressure ? The bias ply will tend to dart more than the radials .
You gave a camber of .5 degrees ... negative or positive ?
As db said , you may also have a bump steer problem , but are you sure there isn`t excessive play in the steering linkage , tierod ends etc ?
