Old 02-01-2014, 09:28 PM
bill37341 bill37341 is offline
Cobra Make, Engine: Scratch-built 427 MR
I've had the same problem. Someone had installed a helicoil at an angle, probably with a hand drill. WAY crooked. Time serts were too small. We used a 11/16 bottoming tap and installed a piece of 11/16 threaded rod, then drilled & tapped the rod. Holds 45# easily. Good luck.
