Originally Posted by ERA Chas
Can you be sure you have the same location and axis that way Brent?
I thought it was easier to find the location with a new boss and filled, machined hole.
Just wonderin'...
Have the head set up on a Bridgeport and locate the hole. Blykins probably overlooked mentioning using a machine because when you have and use them, it's a but of a course? You would cringe not using one. Only when it's a no other way.
On other jobs at work. I've usually taken a piece of threaded stock. Bottomed it and locktite, even chamfered and peened the top out. Then re drilled and tapped on location. As mentioned above I think.
Ralphy
