Originally Posted by Ron61
I would say it depends on where you are driving it. Either would look good and do the job, but if you drive where you may have chunks of rubber or small rocks and pebbles hitting it, I believe the stainless would stand up better. Make it easy to change and then make two so if you want to show the car you can put in the new and unused one.
Additionally, if you drive on coastal routes, aluminum corrodes with the salt environment so you should clear coat/anodize.
