  #33 (permalink)
Old 02-02-2014, 05:26 PM
DanEC's Avatar
DanEC DanEC is offline
The owner found out that the clutch pedal had two different pivot points drilled for the master cylinder pushrod, and he just swapped points. Any chance the ERA pedal is like that?
Yes, the ERA pedal arm does have two positions for the rod to the master cylinder. The rod should be in the outer hole for max stroke. Good question.
Also, the pedal arm is splined to the pedal shaft also and can be clocked as desired. For maximum effectiveness the arm should be hanging just a little forward to the front of the car so that it rotates back in the 5 o'clock to 7 o'clock range as much as possible. If clocked too far back (7 to 8 o'clock area) then the rod will get less rearward (horizontal) motion (and master cylinder stroke) for movement of the pedal.
