!help!
I have a 93 mustang and am now on my 4th throwout bearing!!! when i got the car it was a 4 cyl 5 speed. I did a 5.0 swap and used the 4 cyl trans with of course a different bellhousing, it has a factory 5.0 flywheel, clutch fork, and pressure plate ,new clutch,new bbk adjustable clutch cable with firewall adjuster and quadrant... when i adjust it to where the throwout bearing is NOT making contact with the pressure plate it wont go in gear?? but when its adjusted enough to go in gear its constantly riding the pressure plate!! I read that the new style bearings are designed to constantly turn but mine is not? correct??
