Originally Posted by lippy
Dan, it shouldn't matter what gear it's in or even if the engine is locked. When I press the clutch with the trans in gear it should disengage the trans from the engine and I should be able to roll the car (or turn the wheels if they are jacked up). I can turn the wheels when it is in neutral, so I know there is no problem on that end. Thanks.
Lippy - you're right - other than what Jerry added in my defense my thinking took a detour.
Parking brake is off - right? I'm out of here.
Dan
