Sorry to hear the clutch is still not working as it should. Maybe a spacer is the way to go, it does not find the root cause of the issue, but it does solve the problem.
If you have the time and patience, stay the course a bit longer and try some of the ideas mentioned, to find out what is causing the clutch not to work properly.
One way or another you will get it to work ...
