  #94 (permalink)
Old 02-07-2014, 10:06 AM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
If the dowels are long enough to support the trans before the splines reach the engage starting point--put trans in whatever gear is direct one to one ratio and use a drive shaft snout on the tailshaft to gently rotate the trans shaft for spline alignment---
If you take it all apart again---put machinest dye (blueing) on every part/surface that could possibly touch so you will have witness marks for the contact points---
And I would suggest shortening that snot hub some---------
