  #140 (permalink)
Old 02-13-2014, 12:25 AM
PeterAllen's Avatar
PeterAllen PeterAllen is offline
Cobra Make, Engine: Puckett 250 GTO - LS1
Bugger, bugger, bugger, bugger, bugger, bugger ...
I have spent months and months aligning all the pieces of the rear section someone had cut off when trying to make a roadster from the berlinetta kit. As well I made up pieces that were missing altogether and all the joining edges were chamfered inside and out, I even used a laser to get them positioned within millimetres. I laid lightweight matting at strategic points and then carefully removed the rear as one section.
With easy access off the car I went to town on laying heavy (600g) matting both inside and outside the joins. I made up Q-cell paste and applied it to the outside and started to sand it all smooth. Last night I refitted the section and found the bloody thing had distorted when I applied the heavy matting... bugger, bugger, bugger ...
I've only ever laid up fibreglass in moulds I'd made or relatively small patch work and I wasn't attuned to the stresses created with curing resin of the scale I had used.
I've gone back to square one (photo) and cut the whole bloody thing up and will redo it somehow attached to the shell to act like a mould.
Does anyone have Stephen Bradbury's phone number, I'm in need of some luck!
