Old 02-22-2014, 09:13 AM
wrogers55's Avatar
wrogers55 wrogers55 is offline
Cobra Make, Engine: Backdraft #318, 418 CI, 532 RWHP, Mass Flow Injected, TKO600-Road Race, BMW M3 Suspension, Race Springs (Wouldn't do it again, rough on the street).
Do a search here under "Spring Help" in 2009. I was the original poster. Tony Martin replied as well as some other good info.
I have chassis 318 on 315/17 Nitto NT01s which grip enough to break things if you are not a bit careful, and I run it really, really low. To keep it off the ground, I run the race springs on the rear and standard BDR springs on the front. Probably not your perfect track setup, but works on street extremely well. The soft front compared to the rear really turns in well, but you will need some good experience to get comfortable and stay out of trouble with that kind of setup. It's a rough ride on an empty tank and driver only. Fill up the tank and put a passenger in it and you would love it.
Biggest benefit is no bottoming on the street, loaded, even with a super low ride height.
Good luck.
Wayne Rogers in Hideaway, Texas
