Thread: Penetrating Oil
Old 02-23-2014, 06:26 PM
stephen low's Avatar
stephen low stephen low is offline
I struck a similar issue once trying to remove a head off a laser with the head bolts seized.
Application of heat and shock hitting the end of the bolts eventually freed them all.
Was able to set up a ring spanner and would work the bolt in both directions though a fraction at a time until the whole thread freed up. Got all the bolts out with no damage to the alloy threads that I was aware of.
Worst case though is as suggested, carefully drill out the centre until you can use an easy-out to reverse out the remainder of the thread. If you are down to this then thread damage is a likelihood but correctable too.
Good luck.
Steve
slowy
