Old 02-25-2014, 07:26 PM
madmaxx madmaxx is offline
Originally Posted by madmaxx View Post
I did a buddies jeep wheels today, rough shape. started with 400 on most visible pitted/damaged areas until smooth, than 600 on whole wheel followed by 800. Than used "waynes" kit. Turned out spectacular. the 2" orbital buffer is the key but it is a air hog.
I forgot his trucker lube rouge is a must, it makes the polishing process very forgiving and adds a lot of shine! In factor That is where I stop and can see my reflection in the wheel.
I would almost suggest a quick polish. Then you will know if you need to sand and what grit if any. 85 percent of time you don't need to sand!! Only if you can feel the pitting with a finger nail do you sand. No hand sanding!!!! Orbital buffer which makes a uniform scratched surface with millions of randomly oriented scratches so they don't appear as scratches!!
