Those little angle support braces are fake -- so you can pull those. The dash is going to have to come out a bit, but I think you can get by with just removing the dash screws and pulling the dash back a couple/few inches. Maybe, but maybe not. I don't know if you have the quick release steering hub, but that helps. The steering wheel is a PITA when you're under the dash. Removing a seat helps too. You'll be working on your back with your head towards the front of the car so you can either flip your legs back over the seat or just take the seat out. Make sure you disconnect the battery cables before you go in there....
