Old 03-01-2014, 07:21 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Default Are you interested?
I'll save details for later, just a survey.
Are you interested in a Quality, all USA built PUKE TANK Specifically designed for 351's?? True exact reproduction made from "Air Set" molds instead of the poured standard? (Much smoother and flaw less with Air Set".
No modifications needed to mount to the 351's, has the identical shape, size and ribbing as the original. Black as the original ones or the raw gray casting color.
Price hadn't been set yet but they will be a LOT cheaper than the reproduction tanks on the marker today!
Depending on what I find out, production is probably two months away.
DV
