Originally Posted by dave295
An easy way to check the temp. gauge is to drop the bulb into a saucepan of hot water. Check the water temp. with the infra red or other known thermometer and compare it (ignition on) with the cars gauge. Then you'll know the gauges "calibration" or accuracy.
Motor has a 180 degree F thermostat in it. . . infra red temp gauge reads 180-190 on the temp housing when at operating temperature. Gauge reads 50 degrees C (or about 135 degrees F). I ordered a new gauge. Should be here Monday.
Thanks everyone on this part of the challenge.
