Originally Posted by Stephan427SC
What is the best starter with the most torque for these engines ? which would you recommend ?
Stephan
Tilton $uper $tarter, just to answer the question. Not sure that is your problem. Maybe the existing starter is burned up or not grounded well. Take it off and bench test it. Auto parts stores can load test it. Pull the plugs and put the longest socket wrench you have on the front of the crank and see if it will turn freely (clockwise), just to confirm engine is ok.
Check engine to chassis ground strap for clean connections, and also battery to chassis ground strap.
Sam
