Originally Posted by lippy
Stant 10582, as recommended in the ERA manual. You can get it on Amazon.
I use the Stant 10582 locking gas cap.
It seems to fit well, just aim the 'fixed ears' at the slots in the filler neck rim and the 'spring ears' click as they latch under the rim of the filler neck when pushed straight on.
That being said, it's hard to get a hand in there at the same time, so I lower the cap using the key, then push it in to click. Removal of the gas cap with the help of the key is also no problem, but once the cap is out from the filler neck area, keep a hand on it so you don't risk dropping in on the fender ...
