03-04-2014, 03:57 AM
QLD
Cobra Make, Engine: Some kind of FORD thingy, with several pis tins, twin chain driven SUs feeding a Y block, apparently.
Originally Posted by 07cob
Tom
I think that the optimum pitch of the panel will depend on your latitude. 26* may be good for you but down south will need a bit more, and north less. Regardless, the optimum pitch will indeed be important.
Geof
That is true, for me up here that is the ideal senario but it does change a bit the more you go south, you just have to check the graphs for your area, glad you mentioned it as i forget about that.
Nuts,,, Bolts,,, and 2 smoking barrels.
