Ok folks, I finally got around to trying this. Ran it for a while and sprayed in the lithium grease when everything is hot. The pedal definitely returns when it is cold but not once things heat up.
So the grease didn't work--- now I am thinking spring.
Has anyone done this? Recommendations?
The only thing I can see to secure the spring to is a crossing metal bar-- probably 9-10" away from the brake pedal. Sure seems like a long spring, no?
Would welcome some suggestions here. I am very careful at each stop light to make sure I pull the brake pedal forward with my foot-- this gets a little old.
Thanks!!
