Originally Posted by tkb289
I use the Stant 10582 locking gas cap.
It seems to fit well, just aim the 'fixed ears' at the slots in the filler neck rim and the 'spring ears' click as they latch under the rim of the filler neck when pushed straight on.
That being said, it's hard to get a hand in there at the same time, so I lower the cap using the key, then push it in to click. Removal of the gas cap with the help of the key is also no problem, but once the cap is out from the filler neck area, keep a hand on it so you don't risk dropping in on the fender ...
Be advised people, the Stant 10582 will not fit Factory Five gas filler pipes. They have a 1200/1600/2000 slot configuration NOT 1200/1500/1800/2100 slots that you find on the 10582. Not sure what the Stant locking substitute part number would be…if they carry it.
BBryan
