Thread: Brake fluid
Old 03-07-2014, 07:12 AM
patrickt patrickt is offline
Originally Posted by OldFoggey View Post
Federal standards require that DOT5 brake fluid be purple in color. My car is build #889 built in 2010. Did my car get the wrong fluid put in it or is the DOT5 requirement not correct?
You can't rely on the color -- depending on how long the fluid has been in there it can change. Obviously I don't know what you have in there, but DOT-5 is oil based and it won't mix with DOT-3/4 or water. DOT-3/4 will mix with water, but not oil. So....
I would syphon some of the fluid out and then mix it with a DOT-3 sample in a nice clean mayonnaise jar. If they don't mix, then it's looking like DOT-5. Then try and mix it with water. If they don't mix, then it's really looking like DOT-5. Then mix the fluid with some oil. If it mixes, then you're almost assured it's DOT-5.
Anyway, that's how I would do it....
