Also used Vintage Air manual, cable operated valve. Valve goes in the hot water out to heater core in line, the one coming out of the intake manifold. The line going to the water pump is the return line. A manual valve can be partially opened to regulate temperature, wheras a vacuum valve is open or closed.
