The air cleaner spinning around is a common problem with these. I removed 2 carb bolts to the manifold and replaced with studs and locked them down using a lock nut. I then marked the lower air cleaner plate and drilled and then bolted the lower to the studs. Air cleaner now mounts solid and doesn't turn. I hope this info helps.
