I had a couple of hours free to work on the car today so I started finishing up on some of the fiddly jobs that I've been avoiding.
Decided I'd tackle the hand brake light switch, I had a bracket and switch but didn't like the bracket because the switch didn't always contact the the hand brake arm so I came up with something a lot simpler using a small water proof micro switch.
This is the switch.
[/url]
Mounting it was pretty simple I just bolted it to the chassis so it switches directly from the hand brake tensioner. It's pretty simple and it works a treat.
[/url]
This was the last job in the gearbox area so I installed the centre cover gear stick and gear stick boot cover.
[/url]
I've been searching the net trying to find some hinge covers the Kirkham hinges are nice cause they're identical to original so the original style hinge covers should fit.
This is the standard Kirkham hinge I've started making stainless steel components for the anti intrusion bars so that's the plate on top of the hinge plate.
[/url]
And this is the hinge covers I found there fibre glass and fitted perfect even with the additional plate for anti intrusion bars.
[/url]
Once I have the bars in and the doors reupholstered I reckon this will all look pretty neat.
