Originally Posted by madmaxx
Yes there is a ground wire in the trunk from the battery to frame. It breaks at the terminal where it connects the frame. Pull up the carpet behind the battery tray and remove the terminal, its the only way to inspect. You should have noticed your amp gauge going crazy though.
I have noticed the amp gauge jumping at idle or even when I give it gas at a stop to keep it running. So remove the ground and do what the previous forum member recommended?
Thanks,
Lou
