Old 03-10-2014, 08:15 PM
Cobra #3170 Cobra #3170 is offline
Default Stock springs
Originally Posted by my427cobra View Post
Just curious. Does anyone know what the front and rear coil spring ratings were on the 427 Street roadsters.
And I would imagine the comp versions had higher spring ratings?
Greg
I have some in the garage but they are not marked, they were quite low as I recall something like 350 and 450 lb/in respectively. I am pretty sure Nic or somebody else will know. If nobody responds I can measure the wire diameter, spring OD and coil count to calculate the rate. Some time in the late 1970's I had Hypercoil wind some replacements for me that are slightly stiffer but have the same coil count and spring diameter, they were marked as are all Hypercoils for rate. I can check and see what they are so you would have a ball park number, They were really expensive at the time so I switched to 2.5 OD after that because it is a common size for race cars.
