The starter clicking noise is due to not enough juice getting to the starter. The piston tolerances wouldn't cause a starter clicking noise. The heat is causing a poor connection between the battery and the starter. The heat must also be causing a poor connection between the battery and the ignition system. Probably the same connection somewhere. Check your big thick battery connections in the engine compartment?
