Great to hear and see people going the next step in their personal safety.
As a heads up, if your thinking of buying new/replacement harnesses, buy a Hans compatible one. They tend to be narrower over the shoulder and have a shark toothed grip on the inner side which helps with the belt maintaining its position over the Hans device when your belting up and staying in place when driving etc.
A 3 inch wide harness is a bit of a pig with a Hans as it tends to sit half on the device and half on your shoulder which then leads to it wanting to slide off...
Also, get the pro's to fit your anchor points and if you can afford it buy the "sliding tethers" option rather than fixed. Gives you the ability to turn your head a little more. Just an fyi.
Spookypt
