I checked the linkage and it's tight the Bog occurs when hitting the gas in third gear around 2500 rpm's so the linkage has to be engaged. Also using the brown CAM helped and it has more lift than the green CAM I removed. What's a good timing at idle and then advanced. I have an MSD mechanical advance distributed.
Gary
Backdraft 1048
