Old 03-18-2014, 12:30 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by genolan View Post
I was also wondering if the 30cc pump would deliver fuel along the entire travel of the cams outlined in the Pump Cam Lift VS throttle position graph on the holly site. I realize that a .25 squirter would last longer than a .35. So at what throttle rotation(in Degrees) would a .35 squirter on a 30cc pump run dry?
On gentle throttle opening rates, the nozzle stops flowing when the cam lift versus duration stops, re: cam durations.
The throttle could be slammed open and the nozzle still flows fuel. The purpose of the override spring. Nozzle duration is shortened with larger nozzles.
A "25" squirter is .025 inch, not .25 etc.
Gary
