Old 03-19-2014, 01:44 AM
1795's Avatar
1795 1795 is offline
Go to secondstrike.com and take a look at the gearing calculator. It will let you run through scenarios for gearing based upon wheel size and transmissions. With the .64 overdrive you will be hard pressed to use anything less than a 3.73 rear end. Otherwise you will not be able to get into 5th gear until about 70 miles per hour. Not very useful.
