Depending on availability of small block fords in Belgium a stock cast block can be had for as little as 50 bucks. Add some machine work money for a cylinder bore, line bore and cleaning and you got 300 to 400 bucks. an aluminum block is going to run you somewhere in the 5000 to 7000 range.
" If it wont break em loose in 3rd gear, it aint enough power "
